90volvo
- May 27, 2017
- Eldorado Springs Mo.
Im trying to help a friend of mine. He purchased a 85 244 auto with 150000 miles. Looks like it has the Chrysler box on passenger side behind headlight. He drove the car home but it ran horrible. I had him do the basics, splugs, fuel filter, wires, cap, rotor and airfilter. That smoothed things out but anything off idle is would bog then die. So I went to go visit him he lives 3 hours away.
I figured it was a fuel problem so, I checked both pumps. The intank pump was not working, he had a brand new pump for different application, (02 ford?). I eliminate the main pump and installed new pump in tank with new fuel lines. I used fuse 4 for power and ran a new wire to the pump. I checked the specs on the new pump and seems its for an EFI and pump 43lbs pressure. Fre the car up, same problem idles great, but hit the gas to rev it up and it dies. I checked the TPS and it clicks right off when throttle is hit.
The car has a weird looking fuel rail so I didnt have any FPR to fit it. If you unhooked the MAF it does better but still dies when you put it gear and try and move the car. For the heck of it I pinched off the fuel return hose. That helped alot, you could rev it up with out it dying.
heres a list of parts he had put on it.
NGK plugs
New Coil
Plug wires
cap and rotor
fuel pump
Fuel pump relay(out of my 90 volvo that I know is good.)
THINGS WE TRIED
- replaced timing belt and yes its setup right. Triple checked it.
-up by firewall is a big plug that has wires that a mouse chewed up. I figured all the wires out but a green wire from engine?
-pull injectors and cleaned them
-pulled air filter housing and piping and cleaned
-Cleaned throttle body
-cleaned fuse panel and installed nices fuses that I had laying around
-At this point I think has to be FPR, The vacuum line has no sign of leaks etc. I have a fuel rail off of a 89 240, so I can put different FPR on it. I have quite of few of them laying around.
-Used couple of can of brake clean to check for vacuum leaks. Im back home to get some tools-timing ligt- test light etc. To take back with me. He is a good friend and I talked him into buying a volvo 240 so I feel like it my place to help him getting it figured out. I wish it was 2.4 cause I am more familiar with that system. Any help will be greatly appreciated.
Im sure Im forgetting some other things. Id greatly appreciate the help. Im about to have back surgery but want to get this lined out for him before I get it scheduled. Im driving back up there this evening. Thanks
NGK plugs
New Coil
Plug wires
cap and rotor
fuel pump
THINGS WE TRIED
