First, I have to say - you are really, really
awesome. I much appreciate the amount of time you've put into relying.
I've been checking a few more things, and. . .
The terminal 11, as far as I know, must ground or the ECU will not function. The ECU is not supposed to be plugged in for this test.
Huh. I have the wiring harness apart at the ecu connector and 11 really does seem, as far as I can tell, to do a simple loop around to terminal 19. Maybe the linking to ground is ECU internal?
→Check the main LH fuse, 25 amp blade type, located out next to the battery on the fender. Then verify that there is 12V+ reaching the terminal #30 of the fuel pump and the LH injection relays under the dash, there should be power there at all times.
That fuse is good (the contacts were corroded, but I cleaned them up, and replaced the fuse), and yes, there is battery at terminal 30 (of the single main relay, as you mention later.)
→Make sure the signal wire from the coil to terminal #1 is making good continuity to terminal #1 (-) of the ignition coil.
I'm sorry, I don't understand. . .
→Try starting with the fuel pump relay bypassed by jumpering the #5 & #7 fuses together.
Yeah. The pumps run when the fuses are jumpered, but the car doesn't start (no injector firing?) Without the fuses jumpered, the pumps do not run when the starter is cranked. BTW, I've swapped in that same relay from two other known running 240's, so I'm pretty confidant it's good.
The ignition system would still work normally, the ECU would not turn on the fuel pump relay or fire the injectors.
Seems to describe my problem.
Wrong again The rpm signal that the ECU sees at terminal #1 comes from terminal #8 of the ICU, aka igntion control unit.
How would I check this? The hall effect sensor that was in this car was definately on the verge of dying (bent trigger wheel, I have no clue how long) so I put in one from the j-yard, and it definately works. (turned the engine over by hand and watched a removed spark plug, which does fire at the proper time. . .TDC, right?)
I'm gonna go check terminal #5 again now, I don't think it was grounded before. . .
