Howdy fellow Volvo nuts
Greetings from sunny California, Los Angeles
Got a 91’ 940se wagon
Did a few mods to my wagon and haven’t been able to start it up successfully, gonna explain my dilemma and see if any of you guys can share some advice cause I’m at a standstill at the moment...
Mods done:
Machined head (530)
Ipd turbo cam
Ipd adjustable cam gear
Green injectors (relay mod)
15g turbo (19t internals)
3” MAF
3” downpipe/full exhaust
Blaster coil
eBayChip (stage4)on both ecu and ezk (gold box)
Welded diff
Full ipd suspension
A/C delete
Oil catch can
Dual stage boost controller
Engine cranks over and starts up after a few times but needs throttle to be applied and moment throttle is released the engine cuts off, no real idle. Wondering if maybe someone here can help and shed some light cause I’m head scratching at the moment.
Much appreciated.
*update*
the car turns on and stays on, idle is solid but afr bounces from 12-14, same thing under load.
is there such thing a negative boost?
the car idles at like -12 psi and never really builds boost in the positive, any help ?vacuum lines seem ok.
also foes anyone have any advice or guide for speeduino being installed into these cars, i have a unit ready to go but don't want to hack my harness unless im sure what im doing. appreciate any advice
(looking to buy a 740/940 clutch pedal assembly, if you have one let me know)
https://ibb.co/LYm1CXC
https://ibb.co/Bw5tzPk
https://ibb.co/fCn6Qcf
https://ibb.co/xJ8rLm9
https://ibb.co/0C7NCbN
https://ibb.co/fNs48CH
https://ibb.co/T1sHWfn
https://ibb.co/QFBSpk0
https://ibb.co/9Hv4z55
https://ibb.co/7zSDRCw
https://ibb.co/xSmMyXL
https://ibb.co/yNkJVvZ
https://ibb.co/sw7smPZ
Mods done:
Machined head (530)
Ipd turbo cam
3” MAF
Blaster coil
Welded diff
Full ipd suspension
A/C delete
Oil catch can
Much appreciated.
*update*
