ZVOLV
<Master Tech>
- Nov 19, 2002
- California
I would pull the torque converter loose before dropping the pan, way less work.
Engine would still spin with failed driveline.
If a converter bolt backed out and is hitting the block it sure as hell won't spin. That's my point.
I still believe that this damage is likely inside the block.
Doesn't seem like it would be hard to pull the motor, remove the head, rotate the bottom end and replace a piston.
Drop another bottom end in it. Even a 90+ B230F would do...but does require drilling for the oil return, and running an oil feed line off the front of the engine.I'm open to suggestions.
M
The expert things they can find a replacement for roughly $3K. Not sure thats the way to go at the moment. Looking at all the options.
NoVA Dad
