Wren
Porkchop Sandwiches
- Jun 29, 2006
- Athens, GA
Which is perfectly acceptable for between the fuel sender and the input of the main pump as fuel is under low pressure at that point. I've been running this setup on various cars for years.The only 7/16" I can find is rated at 35 PSI.
Used 1/2" High Pressure (up to 250 psi) fuel hose. Didn't have many options, this was pretty much it.
You had a workable option with the 7/16". You would be better off with a correctly-sized hose than using hose clamps to make 1/2" hose clamp down enough to fit.
