volvo740best
- Jan 31, 2004
- Italy
Hi All,
I started this projects some months ago when i found a V70II D5 163HP 2002 with 200k KM for a very good price.
Unfortunately the free time for that project is very limited, so i started with the remove of engine and all electrical parts from the V70 and with the wiring rework.
Engine only need the ECM, CEM (due to immobilizer), key reader and the original key.
I also keep the ABS ecu because ECM use speed sensor for a little fuel optimization.
Also found a 960 oil pan and started the mod.
More picture on it later because unfortunately i not have tools and expertise for welding aluminum, so now the oil pans parts are in the hand of an expert
Found and installed a used diesel high pressure pump from a V70II 185HP 2005 that is 3cm shorter respect of the old one
And now it's time for 180? turn of the Turbo, so i have made an adapter
During the wait of oil pan welding, started to take some fitting measurement with a "Gold Volvo Jig"
Basically i need to insert a 3cm spacer on the M90 support for reach the body holes.
And i need also to make/buy a drive shaft spacer (3cm) or find a 6cm guibo (if exist).
Ciao!
Ciao!
