GolfClapperX
- Mar 13, 2009
- TX, not by choice
The reason I say that the medium sized blue wire goes to pin 6 on the round connector to the cluster, is that I have that part of the pnp harness cut out as well, still have the round connector the the blue wire goes directly to pin 6 on that connector. I cut all other wires to the round connector because they did not appear to attach to the LH harness in any way. Same with the pink wire going to pin 3 on the half-circle connector, that connector is still attached and that's where the pink wire goes... at least on the 89 244GL I pulled this harness from. But to clarify, I still have my '85 cluster installed and haven't done anything with the electronic cluster yet. The connectors for the electronic cluster that came with the pnp harness are just hanging loose.
It's taking me forever to get these high-res pictures onto my antique laptop, but here are some pictures of the connectors I cut off which bobxyz was requesting. The lh2.4 connector is indeed an 11-pin like I thought, it's just that there are only 9 wires coming out of the 2.4 harness now that I cut the connector off. This is because pins 10 and 11 on the connector are thick red, burned, and cut off close to the connector. Now that it's been a few months, I really can't remember why this is...not sure if that's how it was when I pulled the harness or if I'm the one who cut those two wires really close for some reason. They sure do look important though. I'll keep pouring over all the little reference videos I took at pnp when I pulled the harness.
lh2.4 11 pin connector:
1.blue
2.white/red
3.yel/red (thick)
4.green
5.blue/black
6.purple
7.(2x) white/pink
8.yel/red (thin)
9.pink
10.red (thick, burned, cut close)
11.red (thick, burned, cut close)
1.blue
2.white/red
3.yel/red (thick)
4.green
5.blue/black
6.purple
7.(2x) white/pink
8.yel/red (thin)
9.pink
