Cole Trickle
- Mar 24, 2024
Are the 1981 Volvo 240s any good? More specifically the 1981 Volvo 242. Im looking at buying one for around 3 grand and was wonder fi they're any good. What are the big issues with them?
Will do. Thanks for the tips/advice.Aside from that it was a nice car, had an oil leak somewhere that I never diagnosed or checked thoroughly.
Engine never left me stranded.
I’d probably change the trans oil once you buy it if you do, check for any mettalic flake, my car had a slipping cone clutch (the part that engages the overdrive) and made it the drivetrain slip in all gears.
That’s all I got to say about it
I'm incredibly turned off by this transgressionsop learn what subforums are
This section is called “for sale” it’s used to sell things, volvo related things
You might try posting in “off topic” for comedy and information
It is also the first year for a constant idle system and I think Chrysler ignition, so it may have the super expensive white cap Chrysler distributor. The constant idle system is another system tacked onto otherwise relatively simple k jet that complicates troubleshooting.81 is also the first year for the side of the block PCV box. Due to limited access to that area of the block. NO one services that PCV box and it's almost a guarantee to be blocked up causing oil seeping and leaks on the engine. If the car comes with records showing the service was done then it may be OK.
tell me about it81 is also the first year for the side of the block PCV box. Due to limited access to that area of the block. NO one services that PCV box and it's almost a guarantee to be blocked up causing oil seeping and leaks on the engine. If the car comes with records showing the service was done then it may be OK.
There's two sides to that equation.Are the 1981 Volvo 240s any good? More specifically the 1981 Volvo 242. Im looking at buying one for around 3 grand and was wonder fi they're any good. What are the big issues with them?
