Boosted2003
- Jan 14, 2003
- Cocoa/Pensacola, Florida
Need pictures of b230k carb intake manifold.
Im going to be using 12:1 compression pistons
Stock 531 head (Have too I know)
Upgraded valve train. 3 angle valve job up to 75 degrees
Nice header
Going to be running a 4412 Holley Carb (500CFM) or smaller
Dichromate Finish
Factory Set 50cc Accelerator Pump
Power Valve Blowout Protection
Manual Choke
Model 2300 W/Center Hung Float
Adjustable Needle and Seat
Ford A/T Kickdown
100% Wet Flow Tested
Will run a nice cam. Havent figured out what yet.
Block mounted distrubtor.
Im not sure what cam I should run. Going to run from like 4500-7500 rpms. Want at least 160hp.
Nice header
Dichromate Finish
Manual Choke
Ford A/T Kickdown
