Mr.Borrie
The Sneaky F*ing Ukrainian
- Aug 1, 2006
- Netherlands
Anyone already did this cause i'm planning to use the ones i bought but i got a few delemma's
Like what engine to pick
- Known good B230F i pulled from my 744 from 89, has LH
- B200 i pulled from a 360 did run but not move it did rev nice and idle nice
- B200 with carb in a 360 i would need to pull, works good
For my 144 i need a carb engine since i will be running LPG on it. I need my car allot so i'm lookin for the engine to be prepped and be droped in over a weekend.
Current B20 is leaking like crazy, i think i killed it, also its running on 2 cylinders and 2 not so well ones. already checked and adjussted the valves but looks like cooked valves since it did not help allot.
Okay so considering i chooce one of th engines and put on the manufold from the 360 (only carb mani i got right now) how would i go about the nex things
gearbox-
Can i just put on the B20 flywheel clutch etc an put on the original manual box for now? might wanna change to a overdrive one from a 740 later on but i need it to be quick and working for now
-What things should i also consider, i saw the breakbox needs to be move/ made longer.
- I saw the exhaust is the same but will i need to make it short/longer to fit?
- trotthlecable mounting?
Thats about all i can think of right now
gearbox-
