wingnutty
- Oct 11, 2008
Which system will offer superior fuel economy on na
Actually, you can get pretty good economy from good ol' kjet. But overall especially if you get a set of chips for LH2.4. You can get just that bit more of economy from the LH pulsed injection. If you want to setup your car for optimal mileage. Then you need to make your engine a 'tight squish' engine. That will make it an engine that resists detonation and makes the engine less sensitive to octane. Read all about it here on the board.
In a nutshell. You can accomplish the 'tight squish' by taking off the head, measuring the deck height of your pistons and buying a Cometic head gasket that gives you that .035-.040 zone of piston to cylinderhead room. Some of the folks used even less clearance than that if I recall correctly.
The car has kjet in it now but is all screwed up with rust in system and bad parts so am looking into changing to somthing more modern and feesable to this year model was trying to determine best and most economic swapHigh compression and LH Jet is typically a good combo for MPG.
I've had several 10.3:1 B23F's that got 32MPG highway using 3.31 rear, M46 combo. Hell, I even had a 4.10 rear end B23F that got 27-28 MPG last year in my 245.
My B230F's they been all over the map, some do great getting comparable numbers to the high CR B23F, but usually 27MPG is doing well with 'em with M46 and 3.31 rear end. Most would do middle 20 MPG-ville.
I am also concerned about getting more MPG's so am going to utilise my megasquirt at last and get a B23F going on it.
I've had KJet do very well too, but it can be a moody beast, some days getting high MPG's other days not.
Yes, LH2.4 will require not only a bell housing engine speed sensor. But you should also add the rear axle sensor for speed. It runs best when it knows vehicle speed. So, you'd have to put in the electronic speedometer and feed the LH2.4 the speed signal.
If I were you and looking to do this economically. I would tune the kjet to be clean using known good injectors and set the fuel pressure to the high side of stock like 80psi. Then install the tight squish head gasket and drive it. Replace all broken vacuum lines. Be sure to use Elring or genuine Volvo gaskets.
That will optimize the kjet for decent mileage and you didn't have to do a whole bunch of engine or injection swap stuff. Then if it's an automatic I would get an AW70 from a newer 240 so you have the overdrive gear for better highway mileage. If it's going to be manual then be sure to get a M46 in there so you have good highway gearing.
When I used to have a 1979 242DL with an M45 in it. I put in a M46 and got 3 more mpg and a 600 rpm drop at highway cruising speed.
is aw70 a direct swap ex. drive line etc?
This was my thinking too ,but are the lh independantly or batch fired also are the fired on clean out ,inother words twice per revolution or once?
