doucheNozzle
Newbie
- Feb 26, 2009
- The Pitt, 15147
Is it noisy like a regular T5?
Oh yeah, but mostly from the release bearing at idle in neutral and decel, I used the T5 bearing but not 100% it has the right i.d., it's been slowly getting quieter though. It's a common complaint from mustang drivers too. When I shimmed the bearings/ shafts i measured 0.0 it was supposed to have .002" but it seems to have worked itself out.Is it noisy like a regular T5?
Do you know what gearing your rear end is?I use sixth gear on mine. Of course only over 70mph, but the fact that I can cruse this thing on the hwy and Still have a close ratio for the lower gears is awesome.
After reading what I can find on the swaps I'm going to go ahead with a used cd009. Those of you that have done it, what year transmission did you get/ which ones will work? Everything from 03-now seems to have the same front cover that the deeworks adapter could bolt up to but most stuff I find only references using a pre 08 transmission.
My rear diff is a 3.73Do you know what gearing your rear end is?
I wouldn't go with a used one unless you know what it came from. The tags can be missing to identify them. I got mine from z1 motorsports, but if you can get one you know is good. Go for it.Do you know what gearing your rear end is?
I have a TR3650 from a 2004 mustang in my 242, I had to swap the input shaft with the later version 2010 + for the correct length 10 spline, which basically involved taking the whole thing apart. Hanlon had a 26 spline input shaft available which makes it almost indestructible. It uses an adapter plate from Hanlon motorsports that converts it to TKO mount on the front. That bolts up to the BNE adapter plate, so 2 adapters but I have a 5spd that will take 600ft.lbs. needed some tunnel bashing but the shifter position isn't too bad had to cut way a little bit of the stock hole but it put the shifter closer. It also has a .62 o.d. which is great above 65 mph with my 4.10 rear end. It turns about 2800rpm at 80mph. The internals are about twice the size of T5 guts and it weighs about twice as much too if that matters. Definitely a 2 person job to install it.
I've got a .80 fifth in my t5z with a 3.91 rear, it's EXCELLENT on two lane backroads. It's terrible on the highway, luckily I never take the car to go sit on the highway doing nothing or I'd drive it off the road. I'm also glad I don't have an extra shift out of a crawler 1st gear to get to a .80 ratio...holy overdrive lol. no wonder it works so well with a 4.10 final
that's an interesting find, what shifter did you use (or just the stock one?) and how's it feel relative to a t5? I've had one t5 that I really liked, the rest have been so-so, and the power handling is not going to jive with my goals anyway :-/
I do not care for the t5 in the blue car, but going from .68 to .62 might tip it over still. I also don't really love the idea of the like .8 od in the cd009, I can more easily source a 4.10 (From the stack of them I've acquired recently...) and would vastly prefer that over stretching all the gears to make a decent OD rpm...
Do like the shift quality of the cd009 though...
What do you consider hyperspeed?One slight consideration, and perhaps it's so slight as to not be an issue a tall, but if you plan on hitting hyperspeed in the car at some point, the driveshaft RPM is something to ponder.
A tall top gear and a low rear end and vice versa are otherwise pretty arbitrary. But I've seen some driveshafts that let loose at high speeds and it often damn near totals the car. Keeping driveshafts RPMs down might be a nice thing to aim for.
You'll be fine with regard to critical speeds. You can spin a stock DS to over 10k without issue iirc.Super...now I am going down the driveshaft critical speed internet rat hole. I started with a stock 740 M46 driveshaft, replaced the front section with the Yoshifab version with the slip yoke and stiffened up the stock center support with window weld urethane. I really can't see this car going over 120 MPH, which at a .354 is ~6000 RPM 1:1, or .410 ~7000 RPM 1:1 if I calculate that correctly. The most I have ever seen is 117MPH at the end of the straight at Big Willow with a .354.
yeah that 2 piece deal works really well. had mine up to 8500 seeeevvveral times, no issues.You'll be fine with regard to critical speeds. You can spin a stock DS to over 10k without issue iirc.
Are you running a damped slip yoke?I also have a modified M47 2 piece, I don't get the vibration issues other people complain about.
I am not, a 1330 yoke I think to match the output shaft of the transmission, I also have an upgraded center bearing, I'll see if I can find my thread with the part numbers.Are you running a damped slip yoke?
