Dealing with fueling issues for a while on my 85 244ti. I believed the cpr to be out of adjustment slightly but when I took it off for the 10th time I noticed it puked varnished Amber fuel out, which is weird cause I know it's clean both before and after the filter so I'm thinking the distributor has a bunch of varnish in it and the more I read the more I feel this could be a part of my problem. Thing is I've always heard to never remove them and the threads I've read where people did to clean them they leaked (possibly pressed from the factory). Searching didn't yeild much but turbobricks what's the preferred method to clean the fuel distributor?
Also I found some Aussie site talking about modifying the cpr (wur in their talk I don't think it was Volvo) to make it adjustable, anyone here done that? Seems easy enough to be able to get the right pressure. Btw I've got a pressure gauge set up for it and I'm getting about 42psi from the cpr which is on the high side but none the less still within acceptable range so idk if it's my main issue causing my lean running (too freaking lean)
