BearForceOne
- Sep 27, 2015
- Clarkston, MI
Here's an interesting problem I've been trying to solve for the last few years. I have a 1989 740 Turbo, originally an AW71 car, since swapped to an M46 from a 1986 NA donor 740. Ever since the manual swap, the clutch pedal has felt extremely "creaky", and impossible to smoothly operate through it's full range.
In the swap, I replaced with new:
- Dog dish flywheel, turbo clutch & pressure plate
- release bearing
- clutch cable*
- shifter bushings
- trans mount
All normal contact points were properly lubricated during the swap, I don't believe anything is running "dry".
What I recently learned however, is that only NA 740's received a cable-operated clutch, whereas turbo models had a hydraulic clutch. Along with this change included a different clutch fork that pivots at a different point inside the bellhousing.
Would this difference be the cause of my creaking clutch? Is it possible the hydraulic system provides better force on the heavier pressure plate springs, and leads to a smoother operation over the NA cable system?
M46/7 bellhousing showing difference in pivot locations, the cable system "pulls" the fork/release bearing towards the front of the vehicle where the hydraulic system "pushes" the fork to the rear of the car, pivoting halfway through the fork into the release bearing
Cable clutch fork (top) vs hydraulic clutch fork (bottom, rotated 180 degrees)
- release bearing
- clutch cable*
- shifter bushings
- trans mount
