Here is a really "new" noise problem for me, with a "time wait" solution as it seems, as we concluded with Gary. Maybe someone else has the same problem or even a solution so, share it !!
The past year i had my open diff replaced with a TrueTrac, as well as the carrier bearings and cover seal. Everything was perfect, no noises or whine. Backlash was set "textbook" perfect -luckily- according to the greenbook. I had it used for over 2000 kms, while not really abusing it. My wheels were 14's with 185/60/14 old tires.
So a month or so ago, i decided to go poly all around, R-brakes mod on the rear (and front) - while kept the old rotors hat to use it as a e-brake (solution by Homer), use 35mm rear hub/wheel centric spacers to install 8,5 inch 30 offset wheels with 235/40/18 tires. Also i used a 25mm rear IPD sway bar, adjustable TRs and panhard (that in the beginning i had them set at equal length as the original - keep that in mind for the "noise"). However, despite all these mods, the diff-axle-pinion-driveline-etc was not at all altered! Not even changed diff oil !
When i took it for a test drive there was a noise with the following characteristics:
- Starts at 80 km/h no matter which gear peaks at 90-100 and disappears at 120-130. No connection to the revs, no matter if i am on 3rd 4th or 5th
- It is heard ONLY when on gas with gear engaged and clutch not pressed, when i let it go it is not heard. (so i think this proves it is no bearing .. since would do it when gaining or loosing speed ..)
- No matter if it is a turn
- It is definitely not road noise or anything "external" to the car.
- As said above changes over speed, but only when on gas and not pressing the clutch ! So if i am on a downhill accelerating and press the clutch it is lost. Same when loosing speed.
- I noticed that when i start moving from stop or sometimes when i press the clutch a sound is heard once. Something like two metals are hit and lock together, no echo of course, just a short sound. Something like if there is a gap on a u-joint.
After seeing all these, i tried to test some things:
1) Raised the car on jacks where i put the 2 jacks under the rear axle so that it takes the weight of the car on its own springs. NO noise at all..
2) Changed the rear u-joint -proved that was not needed though- with a new one. No real change
3) Opened up diff and found that backlash is perfect as in the first moment. 0.15mm. It is even perfect by volvo's specs. The teeth are used on all their length, as back then, so i could see nothing more in there.
4) The big change: Adjusted the panhard (with the use of wheel alignment machine) and TR using a level indicator: +3 on the gearbox plate , -3 degrees on the diff plate , got them in parallel perfectly. Also checked the u-joints with this guide http://www.hurst-drivelines.com/files/Universal_Joint_Alignment_Proc_111606.pdf suggested by Gary and everything seem in order. The calculations gave me 1 degree u-joint operation which is good! The noise changed a bit but not much. Reduced by 30%.
5) Used Motul 90PA Mineral for lsd + 200ml of MotorCoat. Not much changed. Maybe a 10%.
I have been driving with this setup for 1000kms, Gary suggested that this will go away since the gears may re-mesh after 5000 miles or so.. Is it a waiting game ?
So after all these .. my question is "why now" ? Why is the noise introduced now, since i changed nothing in the diff ? Anyone can think of any reasons?
