Forg
- Sep 17, 2003
- Retirement Village, Sydney
In order to fit a CAS I've had a chopper-wheel added to the "wheel" on the front of the crank which holds the accessory-drive pulleys (and which holds the cam-pulley in place).
The half-UFO-shaped (ferrous) metal guide which keeps the cam-belt in place needed grinding down, in order that it all fit back together.
See pikky below, it poked-out too far so I've ground the walls down a bit (no pix after griding it down, the following hows why it needed grinding):
The question is whether this bit should really be painted, now I've ground away a fair bit of it? I don't know if it's coated in something already, you can see from the colour that it is very lightly rusted but it's not super rusty so it must have something on it ... I only have access to rattle-can paintage, and don't want to do a big gluggy job, if I don't need to do that painting. I suspect, however, that I should ...
Thorts?
Thorts?
