thatcher.hubbard
- Aug 21, 2013
- Seattle
I did a couple of searches and couldn't find anything conclusive, hopefully somebody here knows for sure.
I want to put a T5 behind my B6304, which means I need to replace the flexplate with a whiteblock flywheel. An early 850 flywheel is available, but it seems the design was different. How different (and in what ways) is what I'm wondering about. The car is using the OEM Motronic 4.4, so the crank position sensor needs to be compatible (or made compatible some way) and I'm also wondering if the dimensions and bolt pattern are the same. I was also planning on using the starter from my S90 donor car, and my desire was to use and 850R pressure plate (240mm) and then get an 850R clutch plate with the T5 center from southbend/spec/whoever.
