So a 240 guru suggested to me a way to boost the power on a B21F motor was to change the stock fuel distributor to a 1976 version which has a larger hole, thus allowing more fuel to enter the combustion chamber. Apparently 1976-82 models had smaller holes in the fuel distributors. However, is it possible to use the fuel distributor from a 1975 model (B20F) instead which also has a larger hole?
A massive air leak was found -- we poured water over the intake manifold and the injector area and the engine bogged down. I'm having the intake manifold gasket replaced so the manifold will be popped off and I was considering modifying the fuel distributor whilst the manifold was off...anybody else done this before?
