* - You probably know this, but as static pressure goes up, fuel volume goes down. Static pressure goes up when you get into boost on manifold referenced fuel pressures - so just at the point you need *more* fuel volume (high boost) - the pump is putting out less volume. And even with a rising rate FPR, you still have to add boost pressure on top of that. 80 psi of manifold referenced fuel pressure is 100 psi of static pressure (what the pump has to put out) at 20 psi of boost.
Yeah, that's why I was saying you'd still need the rising rate functionality to maintain differential.
Pumps are struggling to put out volume at 100 psi. You'd have to get a MUCH higher capacity fuel system.
Absolutely, most of the OEM pumps out there will be earning their keep to maintain any appreciable volume at more than 50-60 PSI. I will say though, that after an unfortunate plumbing error, we ended up dead-heading my 044 with a stock in-tank...suffice it to say, it pegged a Strap-On 165PSI fuel pressure gauge, resulting in some amazingly low duty cycle numbers, but not actually damaging anything. I think a pair of those things, and you could probably start getting there for street or strip applications without extended runs at WOT. Road race or rally applications are another issue entirely.
