thony
Piston Slap Addict
- Aug 9, 2011
- Quebec, Canada
The story:
A Swedish God: Hey, your AW-70 was dying in your 245 and you bought an AW-71L to do a swap?
Thony: Yes, exactly what I did!
A Swedish God: And you did not follow the proper method, with the Torque Converter that has to be installed in the transmission bellhousing first?
Thony: That's right sir, that's right.
A Swedish God: Then, after bolting everything up, you started the engine and put the transmission to any gear and nothing?
Thony: Yes, pretty much...
A Swedish God: Then you read online that there's a specific method to install these transmissions?
Thony: Hmm, yes sir.
A Swedish God: And you had to remove the transmission again to realize you maybe broke the pump and/or the torque converter.
Thony: In fact I did remove it, again, and the sleeve on the torque converter is bent. Now what???
Okay so that's pretty much the story, without me talking to some form of Swedish divinity.
I removed the transmission and torque converter and the sleeve from the torque converter is bent and the converter itself is hard to put back on the transmission shaft.
I know (correct me if I'm wrong) that I can't use the torque converter from my old AW-70 right? Is there a way to change the sleeve, or to unbent it? And by having the transmission out, would it be worth swapping the AW-71 pump for the AW-70 pump, in case I broke it?
Let me know if I'm missing something, or if you have any suggestion. Doing an automatic transmission swap is already a pain, doing it twice is my punishment for not following the proper procedure, but doing it a third time would be me crying under my car.
Picture of the torque converter, from the AW-71L, with bent sleeve.
Picture of the pump... that's the pump right?
