Last year I lost my beloved '98 V70 T5 to an overheating incident. I could not find any shop local to me to fix it for anything reasonably approaching a rational cost, so I sold it. (Just to avoid the inevitable "bUt ItS eAsY" comments, I don't have a garage and I am already pushing my luck with the condo HOA with working under the hood doing minor things.)
To help avoid that from happening again, I picked up an engine temp/coolant level gauge (VETA-03) from Gauge Innovations in Australia: https://gaugeinnovations.com/en-us/...oolant-level-52mm-gauge-visual-audible-alarms They make variations of the gauges as well. It took a couple of weeks to get here from Australia; it arrived in LA quickly enough but USPS somehow managed to drag out delivery an extra week and a half.
These are 3D-printed housings and they appear and feel solid. The gauge has two small but easy-to-use buttons and a menu. You can set an audible alarm at a specified temp, max temp, etc. Manual FYI: https://cdn.shopify.com/s/files/1/0596/7321/5140/files/GI_VETA_03_Summary_Ver_1_0.pdf?v=1633419960
The coolant level sensor sits on the side of the overflow tank and monitors the coolant level.
The engine temp sensor I have (for now) attached to one of the valve cover studs.
Installation was pretty easy. The hardest thing was finding a way through the firewall for the harness to the gauge; the harness has a small plug on it. I know there are ways through, but on my '93 I could not find or readily access one so I just drilled a hole. Power to the gauge is provided by another small harness c. 6") with another small plug. Wire it as you would any other 52mm gauge. The wires for this harness are REALLY small and fine, so be careful.
I may adjust the location of the engine temp sensor once I have some miles on it and get feedback from a couple 240 forums (i.e., this one and the 240 subreddit).
Some pics:
Coolant sensor installed
Engine temp sensor installed
I ran the wires across the firewall; this is the little junction box for the harness.
Installed and in action
Some pics:
