soroushrajabnik
- Apr 19, 2013
- Los Angeles, CA
My 78 242 with stock b21f has a noisy pump that feels and sounds like its fluctuating pressure directly in correlation with engine loping. I've confirmed that my in tank pump is running and the fuel line connecting the pump to the sender has been replaced as well as the sock filter. Seems like the main pump is on its way out and ive been searching through threads trying to figure out a replacement but everything I find is just open ended suggestions. I have the pump with the outlet on the side, so IPD says this pump - https://www.ipdusa.com/products/6996/104538-volvo-main-fuel-pump-k-jet-200-bosch-0580464126-1336517
is not compatible with my car. Is this because the fittings are different? Could it be adapted to work? Having trouble finding a direct replacement. Any suggestions for a replacement or links to threads where someone has made the conversion or actually has an alternative that works on their car would be mucho obliged
