I think we left off around here. I still have wire tying up and some tidying up to do.
With the engine in and running I needed to get an intercooler figured out. I decided to buy one off of eBay because they are big, cheap, brand new and I haven't read about anyone having issues. It's 31x12x3 with 3" in/out.... big.
We made a bracket out of a piece of industrial shelving from the back yard that mounts it just forward of the lower radiator support. I decided to offset it a bit to the passenger side to make life a little easier for cold side piping with the ABS module. The upper mounts on the IC didn't land in a good spot on the upper radiator support so we made two small brackets and used SAAB 900 ignition bushings as spacers for extra swede cred.
Threw some hydras on for around the yard duty. In the garage with my Dad's '83 242 turbo
With the big intercooler up front the oil cooler wasn't going to get any airflow in the stock location. I wanted to move it up front in the airdam so was going to need to run custom lines. If I was going to go through the trouble I would like to have nice lines with AN fittings. I learned that the oil cooler uses BSP fittings with limited options (BSP>AN adapters were $50). Better option seemed to be cutting the BSP end off and welding on an AN bung.
I got two male-male -10 AN fittings and I cut one end off of each and the BSP threads off of the oil cooler.
He had a coworker weld them on for me who did a great job. He even touched up the factory welds and painted it and all for way less then adapters would have cost.
We made another bracket to sandwich between the intercooler bracket and lower rad support. I had to notch that center brace there a bit to clear the cooler. Happy with how this came together, looks clean and nice and solid.
For hoses I ran -10 AN Aeroquip socketless hose with 90* fittings. I thought the socketless hose was good to work with, it's nice heavy stuff and once you have it cut to length you just push it onto the fitting and it's done. I'll add some clamps off the bracing here to keep them in place.
Also put on some parts I've had waiting; non rusty headlight buckets from out west with Hella H4 rounds. I have a relay setup and 80/100w bulbs to run them. Also put in a really nice looking powdercoated hood latch set up that I bought from Jordan. Also bought an RSI stg 2 cam from him that I'll sit on until I've run the engine a bit.
I had bought some couplers and was starting to think about getting intercooler piping figured out and exhaust hung on it. But, as with the gold car, something that popped up in For Sale caught my eye and sent me off in another direction. I drove down to the CT shore to meet another tbricker (psac). Like the hood latch, cam, and overflow tank bracket these pieces came off of Jordan's car... but are a little more exciting.
Ended up with:
- Holset HX35
- RSI manifold with TIAL MVS wastegate
- RSI 3" stainless downpipe
- RSI 3" stainless exhaust with single magnaflow. (think I'm going to have to get a cat in it for inspection)
- Synapse BOV
- box of assorted goodies
I guess this all follows the general theme of "jumping in with both feet". The quality on the RSI stuff is impressive; I didn't plan on getting the exhaust but it all went together so well it made sense to keep it.
Did a test fit on a spare block and
Unfortunately I saw that my 740 oil cooler setup wasn't going to clear this stuff, and I JUST made my lines. I am buying a 240 cooler plate which should fit fine and am hoping I can just cut and shorten one end of the oil cooler lines. Glad the socketless hose is so easy to get together. The other thing I'll need to do is get the -12 AN oil return from the Holset to the block. I have a pipe thread to AN adapter, so will need to tap the stock return in the block. I wish I had known this was happening when the engine was out and the pan was off
but will have to make it work.
The stock oil return spot has a larger bore with a narrower step at the bottom: has anyone tapped pipe thread into just the larger dia to the step? Or will I need to drill the step out and tap all the way through?
Glad I have the turbo that will stay on the car so I can make my intercooler piping once and for good. Need to buy some 3" aluminum bends and start making pieces. The battery is very much in the way so I'm going to need to move it to the trunk.
Also think I need a heater control valve, since I noticed mine dripping once I got the heater core plumbed
Still lots to do. Spent a couple of minutes driving the car up and down the road and running VE Analyze Live on the megasquirt today. Discovered it runs better with the vac line hooked up to the MAP sensor
. I'd like to get the plumbing stuff figured so I can put the turbo on, make the intercooler piping and then start putting the inside of the car together. Figuring I'll keep boost low on the Holset while I figure things out and learn how to get a nice safe tune on it. Still want to grab a squirter block and put some rods in it to go for some real power.
Long list, would love to have plates on it this Spring.
