There's no ".63 wheel". Stock volvo turbos have used both housings and they are interchangeable because the "stage 1" wheel used on the stock volvo T3 is the same regardless of .63 A/R or .48 A/R turbine housing used.are you saying you have a .63 wheel in a .48 housing ?
just get the prequiite cossie housing , cost an arm and a leg mind .
Stage 3 turbine wheel is larger than stock, and requires machining to fit in a .48 or .63 stock volvo t3 housing or a stock Cosworth housing (at least the housings I've seen).
The Cosworth housing didn't have a 3" outlet.
The Cosworth housing had a very direct flow path for the wastegate hole, but the turbine outlet was angled down towards the outlet into the downpipe. seemed like that could have been better, but probably not worth fussing about.
I went with the ATP Ultimate WG instead. 3" outlet, already setup for a v-band, so no welding to cast iron. turbine outlet points directly at the downpipe inlet. Plus I'm not using a T3 turbo so I couldn't use a Cosworth housing with my turbo, but I didn't really want to either, after having one in hand. I didn't like the 3-bolt flange either, but few do.
