- Dec 25, 2002
- mont, AL
swap distro.
I can send you an msq from a car I got running last night. 2.2 box, ms1 triggering a bip off of spark output a. lh 2.2 distributor, resistor on pin 24, hall return on pin 25. All the coldstart/cranking/fuel table stuff is wonky because my objective was to get it to start and idle..everything else is up to the owner.
check this
no change. cap and rotor on new dizzy very nice and shiny
How is the board wired with the bip?
What about the old one?
Any signs of firing between the towers?
old one was old but I didn't see anything wrong with it underneath
Very Important: Set Spark Out Inverted = YES and set the Dwell to around 6.0mS for cranking 3.5mS for Running and 0.1mS for the Minimum Time as a starting point! Also set LED17 as SparkA output in Codebase and Output Functions!! Read the Software manual for more info!!
