Pietercc
- Apr 5, 2019
- Stockton,CA
I've already tested the maf according to greenbooks, spent a night looking threw mine to find anything there. over all I'm done with this issue, I will be switching to 2.4 soon
Does a LH 2.2 760T have a "2.4" type power stage(mounted on fender near battery) ?Next I would move on to checking the connection and possibly trying another power stage. They can get corrosion in the connector being near the battery. I'd also check the resistance of the coil. Original spark plug wires are around 500ohms per foot.
Check out this old thread (post #13), it has good MAF measurement information and helpful links:
AMM testing procedure
OK, I need a new AMM and I would like to know the resistance values across the terminals so that I can test junkyard AMMs before I buy one. There has to be a procedure. I think I have even read it before. I have had AMMs that allow the engine to run, but the car idles like crap and gets bad MPG.turbobricks.com
In theory... If you mapped the signal at all flow rates from some good LH MAF sensors, and also made a similar map for a more modern, easy to source MAF from a different car, you could create a conversion table and set up a microcontroller based system to run LH with a modern MAF.Last summer I build a simple DIY flow bench project using a shop vaccum cleaner and also if I was not able to drive the MAF to work at it full output I was able to compare its signal with the output signal of a known good MAF connected in series to it (so that they have to measure the same amount of air).
We would need to get a database started with people stating their own values, we just need to make standard measuring parameters.It was the same idea I had but to be able to test also the MAFs of other cars by using the same known well working MAF that I use as a reference.
The picoscope software that I use to plot and compare the two output signal could make this job pretty easy.
An aftermarket MAF today is relatively cheap but what is missing to me (and I believe not only to me) was a valid tecnique to check if a MAF is working well or not that it wasn't to simply try to install it on the car and drive it for a while.
