- May 11, 2007
- Niketown, OR
That's healthy enough. Mine fills a glove in a matter of seconds.
OK. Wait a sec, I'm confused again.
We want to draw blow-by out of the crank case with vacuum? If I snap a glove on the oil fill and it inflates, we have pressure? And that's bad?
What else leaks?
What did you do to the B21ft before tossing it in?
Are you *sure* it's the RMS?
The front main seal can also leak and let oil run down along the pass side seam between block and oil pan and then collect/drip from the bellhousing area.
I replaced a RMS and oil pan gasket only to realize that the source of oil was really coming from the front of the engine.
My oil pan has leaked by the rear main seal cover ever since I went +T. Have not fixed it yet. Once I have the engine cross member out for shortening I will replace the pan gasket again and hope it doesn?t leak. I?m with you on hating leaks for sure.
LC4CARL said:Pick up the torque arms from the machine shop this afternoon. Took out the squeaky poly bushings and installed IPD rubber
Shortening?
Are you sure it was the torque rods? Mine do not squeak. That?s weird. Could be something else...
Yeah so I can lay the frame out without hitting the crossmember/oil pan on the ground. Because chicks dig you layin frame!
