Ιt seems that we have a difficult situation here. Let me explain in detail:
I have a M90 on a B21ET which worked perfectly with the dog dish flywheel with the master - slave cylinder setup from a Volvo 740: FAG S5394G (master) + FAG 6472G (slave), engaging and disengaging at a normal position and also a reasonable foot pressure.
Then I changed to a steel flywheel by Bakaxel.se, a 765 clutch and a 6 puck sprung clutch disk also by bakaxel.se. I shimmed the clutch fork with 2 shims and used a long neck pivot ball. The result was that the clutch fork almost maxed out the slave cylinder which was good, because I could use the whole pin travel of the slave cylinder.
The clutch fork can be pressed towards the slave pump by 1,5mm .. it is that maxed out !
However there is a problem when the engine is running: The gears can not shift smoothly, they need too much force to shift. This means that the clutch is not disengaging fully. Also the clutch engages and disengages/engages too low (in the way it does), close to the firewall. Ok, i know everything is new, however there should be some more clutch fork travel to work as it should, and with a higher engaging pedal.
The reason for this problem is that the 765 needs some more clutch fingers movement, more than the M90 stock config, to disengage. Jonas from Bakaxel said it needs 9mm to open up. No idea how much the old one needed, but definitely was less.
So the first task is to measure how much is the additional clutch fork travel needed to function properly. I am thinking to make an adjustable pin just for testing purposes by some kind of rod to find out how much more movement it needs to disengage. The slave cylinder will be maxed out totally plus the clutch will not engage fully, but I am just looking for the extra travel to disengage.
However this is half of the problem: how can I achieve this "unknown" extra movement ?
The slave cylinder's bore is 22,10mm and by considering its bore and movement I calculated the master cylinder's bore that is about 19mm, which is what is probably the spec of the 740's MC. It also makes sense because having a smaller bore MC than the slave, gives a lighter clutch pedal.
Also measured the travel of the MC which is 25mm and the clutch fork's movement (which actually is the same with the slave cylinder's movement) at 17.5mm. There is an additional 21mm of travel in the slave cylinder until its piston comes flush to the face of the housing. To increase the travel of the clutch fork there are three solutions:
1) Find a master cylinder with more stroke than 25mm @ 19mm bore. This could be a 264 MC which as Dave Barton says on his site has a stroke of 33mm @ 19mm. It is a unicorn to find though and I am not sure that even if I found one used I could trust it with such heavy clutch. This however would result in a same effort pushing pedal as now.
2) Find a MC with a larger bore (eg tilton). Would make the clutch heavier
3) Find a slave cylinder with smaller bore. Would make the clutch heavier
So here is where I am stuck. Any suggestions/opinions ?
