bugjam1999
- Aug 18, 2015
Hi all,
Looking to add an additional oil pressure sensor to a b230fk, for connection to a maxxecu standalone. I’ve already got a vdo 2-connection sensor in the standard place, for the idiot light on the dash and a 52mm oil pressure gauge.
I can’t find a sensor that will output to all three of the above, and the adapters /tee pieces I’ve found so far look like they’ll make the whole sensor and extra sensor arrangement a bit big to fit in the restricted space behind the alternator.
Am I missing obvious? I’ve thought of drilling and tapping the big banjo bolt on my oil filter return arm (same as RWC used to drill and tap for oil temperature sensors) but if there was somewhere else that I could use or a fitting I could use that’s just bolt in that’d be great.
I’ve seen banjo bolts with oil pressure sensors in them- perhaps the oil feed to the turbo?
Or a small sensor that’ll fit in place of the plug on the front of the block under the water pump, where the oil feed for the turbo on a +t setup?
Open to suggestions,
Cheers
Cheers
