Forg
- Sep 17, 2003
- Retirement Village, Sydney
So I've finally gotten around to cleaning the no-aircon PS pump bracket for my 242GT and sorta-kinda installed it ... and it turns out the hoses are too long, there's just no way to make the pump fit in the new position as a result. I had hoped to get away with NOT disconnecting the hydraulics, but since I have to change hoses I'm in for a messy treat ...
Thoughts on how best to approach this?
It's just auto trans fluid isn't it? This bit I can look up!
Should the first step be to open the lid & syphon as much out of the reservoir as possible? Then disconnect the hoses?
One I can cut down as it's just a hose-clamp fitting, but the other screws into place. From memory, both ends also screw into place at the rack end, don't they? So because there's a screw-fitting at either end of the pressurised one, I assume I'm going to have to buy an entire new hose - there's no way to shorten something like that is there?
It's getting dark & I can't be arsed messing-around under it tonight, but how much of a PITA is getting to the hoses at the rack end, particularly with exhaust & turbo in place? This must be doable without raising the engine or dropping the subframe - I hope?
Also … anyone know where you can buy a HP hose for a 1980 240 without aircon?
