JulezSteele
- Aug 10, 2003
- Houston, TX
Basically my car will stall out or almost stall if I let of the throttle quick. Its really notiable with bumper to bumper stop and go - My idle will dip wicked low, engine shaking everytime i let off the gas. With the hood opened hand on throttle, I can almost stall the engine out if I rev quickly at idle(to a point of hearing the intake with the ricey bog sucking sound) (Cone Intake) , after letting off when the rpm's go back to down they dip way too low but a second later catch back up to normal. You can hear a rush of air flow back to the filter. Is air being flowed backwards tripping the AMM? I'm guessing the bypass is working, I replaced it with a brand new porshe valve. My mechanic said there is no vacume leaks at all, and my brake check valve is fine.
Ive had this problem for so long and I really dont know what to think of anymore. I just want to drive it normally. Ive replaced the IAC, tank-pump, FPR. Ive posted it up before but maybe I'll get some new ideas.
I put this in peformance related because I have +T, and it didnt happen before the conversion
-Julian
-Julian
