Ran into a bit of a problem with my wiring recently. First, I was stupid enough to try hard wiring a non-oe power antenna without a built-in relay on it to the original connection point (which now I believe has f****d something up...) so I hunted down a little bit where it might be shorting at.
From evaluating what is going on, I have formulated what I know is working and is not.
In order for my amplifiers to get power, the antenna switch on the dash must be in the off position (top part of the switch out) ... and in the antenna connection in the trunk where the antenna should plug in I have a 30a blade fuse to complete a circuit (I found that this completes the circuit by some luck I suppose... so that allows for sound to come out of the system... kinda).
So, from what I have been thinking as of late... I believe that a fuse on the rear of the head unit is blown that controls the antenna. Often, the tiny fuse can't keep up with the stereo so the amps lose power often... but that is assumed I suppose. I now have a oe power antenna installed, just not hooked up.
Let me know what you think could be wrong, as I am no wiring expert. The stereo was installed like 4 years ago so I wouldn't remember what anything would look like unless I tore it all apart...
Just a wtf was I thinking moment. Thanks in advance if someone can be of any assistance.
