I started tear down of my Explorer 8.8. Still waiting for my other passenger side axle to arrive, but that should be here on Monday. So far, from my crude measurements, I will still end up with the driver side being 1" longer than the passenger side
I thought that it would center the pinion, but I guess it just gets it closer.
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQZXhPMVhCbDRhRjQ/preview" width="640" height="480"></iframe>
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQZm1MbkVBUG5LTDg/preview" width="640" height="480"></iframe>
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQei04ZUQzZld2RG8/preview" width="640" height="480"></iframe>
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQdHhOZFQ5WnhBT1k/preview" width="640" height="480"></iframe>
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQanVGYnI4MVNXMlk/preview" width="640" height="480"></iframe>
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQTkVuZEJockw5YVU/preview" width="640" height="480"></iframe>
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQTVZuWjIwT3FYQjQ/preview" width="640" height="480"></iframe>
<iframe src="https://drive.google.com/file/d/0B9M6uoq2GqnQMWFhMFN4Ql93N3M/preview" width="640" height="480"></iframe>
All of this is getting me thinking about my rear suspension. So far, I've decided that I will be doing away with the stock configuration and going to a Competition Engineering 4 link. Just not sure how the frame brackets will play into it all until I get the kit.
Then its a matter of coilovers.... there s few options
~$400 I can get a CE kit, 3 step adjustable valved shock, 2.5" ID spring with 4" adjustable perch, and it comes with axle mounts that allow for 3-4" of adjustability there, and some progressive rate springs from QA1 and I was thinking that a 150/225 would be good for the wagon and it's utilitarian side.
~$500 for a QA1 double adjustable shock 18 comp/18rebound, 2.5" ID spring, 3" adjustable perch, axle mounts that have the same 3-4" of adjusablility, same springs.
~$350 Used Afco rebuildable shocks, 3 way adjustment, same springs, perches, axle mounts... only deal is USED...
I will probably end up with the CE kit, an if the shocks suck, I can grab a set of the QA1 doubles and see how those do.
Well its my final week at work next week, I get to train someone to do a job that I've been doing for 12 years and I only have 4 days to do it! Sounds like a good enough amount of time... Thanks management. But oh well I get the rest of my PTO cashed out and I can start ordering parts for the rear suspension.
