The problem we run into here is that we have a strong market for most parts and machining and some good tuners and builders. But in Sweden the b230 is like the 350 or Ls in America . They built it from the ground up and regardless tuning it for so many years they have made it look easy to put 500 hp in a DDturbo car and 200 hp in a na engine all using 530 or 531 heads . What is it that you are after . Best way to do it is go across the pond and learn from the best for a few years come back and make what you have learned easy and share what tb may or n ay not know.
Swedish run to much boost .
FYI fire ring the block
You don't have to go and live there and suffer from drinking 1% beer for outrageous money or being shocked senseless at what ordinary food costs, and fuel costs, and ordinary shoes and everything else costs, or suffer from an impenetrable and inconsistent bureaucracy in every aspect of life----others have suffered already for you...
All you need to do is learn to read the language....and read..
And others have done that already...
And really, a lot of the juicy information is numbers...and they're the same..
And what I was referring too was this article from 1992 or 93 comparing Stock 240 to VOC to National Class, later called Grupp H where the Grupp H car was a typical for the class 2300 8v on 48 Weber DCOEs:
Picies kinda big but I wanted the text clear..The caption to the top piccie says in there "according to the test data the 230 hp Volvo is a smidge quicker than Per Svan's Group A Astra (a full spec lighter 2,0 16v Opel with a beautiful Cosworth head and BIG runners and a 6 speed GM/Grtrac box)
Look at these figures for the intervals---THIS is one reason they build better stuff: DATA.Comparisons. Baselines and results..THIS is something that gives you ideas to aim for--and to compare--something we don't do here in Turboprickerland or even in the silly rally world I am mired in. Everything is measured by "I
LIKE it"
Compare:
The article does point out the acceleration difference--pretty amazing, and says, of course the Grupp H car has better suspension and brakes--which also will have a big influcence on SS (special stage) times...
Its really frustrating when this stuff, this info is all known stuff, no magic, easy enough to do, doesn't have to cost like it does there--because we aren't there where every job pays so much more (because it has to when EVERYTHING is so much more expensive), and in fact in many ways now, we can do better...(pistons cost much less here than there then, bitchin rods NOW are cheap, steel light flywheels cost half what they cost there...bearings are cheaper, gaskets cheaper...cam belts and springs (Mitsubishi 4G63 being perfect) are cheaper..
Just Carbs or ITBs cost more..
And good cams.
