Zev Fisher
- Oct 17, 2020
- Boston, MA
Hi All,
I bought a 75 245DL which has a 90s era B230 Penta engine (AQ151) in it with Petronix ignition and a Weber DGEV carb.
According to the book, the base timing for this engine should be 6° static at 850rpm and between 32 to 36° full advance at 4200rpm. This is similar to what the automotive (non-penta) b230 timing would be for a B230.
Here’s where things get weird. When I put a timing light on it and adjust the distributor it runs terribly down around 6° at idle and is much MUCH happier above 18° even closer to 23° base timing.
It’s been like this the whole time I’ve had it and I always figured the intermediate shaft was off by a tooth, but I just did the timing belt and can confirm that all 3 alignment marks were all dead on.
At that point I figured the damper had slipped, so I replaced it with a new one. Got the same weird readings when I redid the timing, so I further confirmed the balancer notch position with a piston stop tool, so I know the balancer mark is also correct.
I don’t understand why this motor would need so much static timing to run well. What am I missing?
