Lucky the Smiling Pirate
roadkill
- Aug 4, 2005
- Phoenix, AZ, USA
so I'm pretty sure the AC compressor has been kicking on and off as recently has a month ago but it isn't now. None of the wiring leading to it appears to be damaged but in any case even a month ago when it was kicking on it took forever to get cold if it got cold at all.
This leads me to think that I'm low on refrigerant. The problem is that with the compressor not kicking on, I can't get an accurate pressure reading from the system and I'm worried I'll pop something if I overfill the thing.
I have one of those large cans with a gauge and filler attached to add some refrigerant and it says that if the compressor doesn't kick on to add half a can and then measure again. Is this safe? Right now, with the compressor off, the gauge reads something north of 150psi (the gauge goes to psi and the needle is pegged).
