volvo240e+t
- Oct 23, 2007
- Iceland
I chose this placement because I wanted to try 65cm runners and low angle collector with the new camshaft(KLR S/T5), and to use the space in front of the engine.Turbo placement: why?? Wouldn't you want the manifold runners shorter for better response? I get equal length, but if you are always in boost who cares?
I have never tried the stock manifold but I doubt that the stock manifold would work with a long duration camshaft like the KLR S/T5. Its probably very nice to use the stock manifold in a low hp street application to minimize maintenance.My first thought is why? You probably have more power with a stock 90+ manifold.
Im using the stock water pump.What water pump are you running? Engine management? Is radiator in the trunk?
Guys have dynoed over 500hp on a stock 90+ manifold. I understand your racing it just seems like odd packaging. Even for a drift car. That cam is to big for a stock head I am betting. What are your power goals?I have never tried the stock manifold but I doubt that the stock manifold would work with a long duration camshaft like the KLR S/T5. Its probably very nice to use the stock manifold in a low hp street application to minimize maintenance.
I Would love to see the specs on a motor that produces 500hp on a stock manifold and at what boost and rpm.Guys have dynoed over 500hp on a stock 90+ manifold. I understand your racing it just seems like odd packaging. Even for a drift car. That cam is to big for a stock head I am betting. What are your power goals?
This is an intercooler from klracing, Im dont remember what size exacly, I would guess around 500x300x115 with 3 inch pipe.What kind of intercooler. Cheap ones can really restrict at higher rpms.
Thank you.I dig the arrangement. Header looks really cool, and the forward placement should keep the turbo from heat soaking. Not sure why anyone would recommend a 90+ for any sort of high HP application, the header is the only answer. Is the car up and running with this setup?
