could you explain it more to me? are you talking ford racing injectors? how much do they run for?
As described previously, there are two types of fuel injectors... high impedance and low impedance.
The volvo non-turbo injectors are high impedance.
the volvo turbo injectors (numbers 357 and 804) are low impedance
The low impedance injectors (period... whichever car they come from) will require ballast resistors.
Some vehicles came with high-flowing
high impedance fuel injectors. The mid-late 80's ford supercharged thunderbirds came with 29lb/hr high impedance fuel injectors that flow as much as the low impedance, volvo turbo fuel injectors. These are a direct swap into the volvo.
They will not require ballast resistors.
Their model number is 756, info can be found in the fuel FAQ about them.
They can be found on ebay and wherever supercharged ford thunderbirds are found... ie, the junkyard, your neighbor's driveway, etc.
Your profile says you live outside Atlanta... if you go here
www.pullapart.com, you will find an excellent pull-a-part type junkyard which is not too far from you.
