142 guy
- May 31, 2014
- Saskatchewan, Canada
Why not just use a hall sensor built into a distributor? Like from a 75 240. Just an easy guaranteed squarewave and you won't have to mess around with airgaps.
That would work if he was prepared to convert back to the equivalent of triggering off of the ignition points. The 4 gap sensor 'wheel' in that type of arrangement would be equivalent to a 2 tooth crankshaft wheel which means he would be losing an awful lot of resolution on his tach speed signal. Not so good if you are attempting to implement ignition control in the Megasquirt.
If he wants to go that path, he doesn't need to find a 1975 distributor. All he would need to do is install a Pertronix module on his existing distributor with pull up resistor and lock the advance mechanism. It does require advancing the distributor timing significantly compared to stock which can create some problems with the phasing of the rotor in the distributor.
Since there is no cam / cylinder position signal with this arrangement, it would preclude any type of COP or wasted spark arrangement.
