- May 27, 2008
- Rockland County, NY
From Sat. Was quite a rainy day, but still fun
I wasn't planning on it, however I expect this and the V8 will potentially drop the nose. I have the 18" advanti hybris with V70 sized tires to try after the V8 is in, so maybe that is in my future ...Are you going to roll the fenders? I would love to see how that looks, I'm running 302mm rotors with 17" Audi rims so I get some rubbing going over inclines at full lock with stock front springs.
KOYO or CAM? Funny how they replicated the ZF "waffle pattern". Former, one or the other is smooth, as I swapped one of the JAPAN racks into my old 92 sedan. Going synthetic or ATF F?
Will do .lmk how the install goes, my rack is leaking out of all its seals at this point. It has decided that my 740 needs to be a leaky volvo somehow...
I'm thinking of going with a S40 electric ps pump and relocating my altenator lower and maybe trimming the throttle body fins down so I can run my stock hood. I might need to do some pie cuts on some pipe to get my intake at the right angle.
yes its the truck intake, I've been contemplating going to a lower ls style intake but don't want to drop the 1k for a fast lsx and no one is responding on marketplace that has a good ls intake that will work with the lm7 headsWill do .
I also have a P1 Ps pump & fittings, plus the pwm controller off eBay, in case I need to do that with my V8.
With yours, isn't it the truck intake? That's more of an issue? As far as the height? That was one reason I went with the LS intake.
I think I bought the Camaro (LS6?) intake: 12573752 and Felpro MS 92438 seal set - it fit the cathedral port head, which is LM7, I think. There's one for under $400 on eBay right now- has a minor crack outside one port edge
the lowered TB meant modding the mount flange to clear the water pump
I saw that one, i might just pull the trigger on it, its been relisted a few times iirc too
edit: do you know what uppper radiator hose you are going with yet?
on other question, iirc you are running the truck block, did you also run a spacer on the water pump so that you could use that same truck crank pully? I'm making a jig so I can go to the parts store tonight and see if i can find a radiator hose thats for another vehicle that will fit for my upper since that will change.
I think those were from another thread, but the becool radiator is the one I'm running, I'm gonna check that upper hose as well as that will prob be the only one I need to change.
edit: thats the exact radiator I bought last night, I made a coat hanger template and found the same one. apparently one of the cars its compatible with is a 140
