745 into Pickup
another pic of the hose layout, with steam vent tube
index.php
Going to go back to the original headlamp setup. I found a complete set with the frames, my originals were toast, and the lenses were yellowed. The problem with the Depot Ecodes is that the adjusters are crap - I haven't been able to get the the low beams or fogs properly set since I put them in.
I do prefer the way they look, but I need good lighting for all the early morning & night driving.
temp-Image4-Seq-Dq.avif
temp-Imagexp-Mf-QH.avif
I used H4 LED bulbs for mine, if I can figure out where I got em from I'll link you.
Hi - thank you Corivus - I still have the original harness connectors, so I was going to get 9004 LEDs - I've used Auxito brand in the past, which are not the cheapest, however they have the built in fans/heat sink for heat dissipation at the back. I have the H4 version in eCodes now. It would be this one, not too OT in terms of output level. What brand did you use?
Finally got around to this - made the brackets needed to refit the single lamp units, using some suitable gauge leftover SS sheet
index.php
index.php
Test fit grille & grille brackets, which attach to the same headlamp mount brackets
index.php
index.php
Back to the base model nose job
index.php
With the fitment done, I moved on to rewiring the bulb sockets (back to original configuration)
index.php
Made a new adapter harness for the dual filament bulb holder, to replace the two singles. Also went with a later model socket that does not use those older bullet type connectors. They don't actually lock into the bayonet fitting, so I need to modify the sleeve to add an alternate seal
index.php
Nice.... I bought that same kit for my old 92 sedan... same templates, lights. Did yours coming with factory harness & relays? Mine was the whole shebang.
That bumper didn't last 6 months when a millenial (on her phone) drove right into me at a 3 way stop. After replacing that front bumper & grille, I knew it was time to sell that sedan. Nice work, easy peasy compared to the things you've done.
I did have the entire kit with harness, switch & relays - mine was pre-wired for fogs, so I didn't need the harness, and I got the dual fog switch, and the relay is specific to just a few years - the generic cube will short out the headlight switch yellow/white wire all the way to the fusebox, ask me how I know :mad:
Sorry to hear about the damage to your old one - that sucks.
yes, this is easy, mentally relaxing work. The X1/9 is finally leaving today, so I can start rearranging the rest of the garage & prepare for the V8 conversion.
Was it weird to see a long term project drive away? My old "cheap thrills" sedan left on a car hauler, and it was the oddest sensation.
It was indeed! in addition, I'd never seen the car rolling in it's current form - no one else has driven it besides me, so it was definitely weird.
