ovlov760
- Jun 2, 2003
- Midwest - IL
I found green LED lights that I think are a closer match to OEM. Still too green, but close enough I guess.
The LED lamps appear quite dim inside the dimmer switch given the direction the light is projected, so I glued a piece of tin foil inside the housing. That improves things enough lighting wise even if it's a crude solution.
