Nice to swap some Engines.
Saab into Volvo is really to upset some people i Sweden
But just do it , just fun to have some more Power in the car.
Hey Guy without name. Do you work for Northbike?
The rear diff is with a Visco I think. You have to remove this stuff too. Do you think the Diff and the driveshafts are strong enough?
You have to weld a lot if you want to fix the front beam into the body again.
The angle between Steering rack and Coloumn is amazing. Wat kind of cardans you will use?
Good fun anywhere. I'm now in the decission to swap a B204L (yes Saab) or a heavy modifeyed B230FT into the Amazon...
For this reason I'm interested in your front Mercedes Spindles too...
regards, Kay
No name guy is me
Joakim is the name.
Jay Jay by nick or just J(ay).
No not northbike.
I did work at Motorcentralen earlier.
That's the local VAG Cars dealer and workshop.
For now i do not think anything is strong enough.
But to start with this is what is avalible so.
I will use the axles from the original car.
The Audi A6 (kardan) middleaxle and rearaxle.
About the frontbeam.
I need to weld alot anyways.
But not more then expekted.
Have som isue with hight for the new Engine.
That's why i have grinded it open and are going to make extra supports inside.
The steering rack will not have the angle on the pics.
The steeringarms is hanging loose in the pics.
So it will be better later on.
The amazon have spindles with bolted steeringarms allready i think?
So for that reason you can use what you have if you do not want to make new ones.
In my case it is because the SFRO(carbuilders organisation) needs a big enough change to be able to register it as a new build.
If you have som questions just ask.
I will answer IF i can
